turbo XS MBC w/ 16 G
Jerith
70
Apr 28, 2002
Can someone please tell me how the hell to connect the 2, I have an injen intake and a Turbo XS BOV.
Thanks
Noone knows how to hook up a turbo xs bov to a 16g???
You did not just say you are trying to hook up a BOV to a turbo I hope...
Here is a picture to give you a good idea. This is a picture of mine before i put it on my car.
I meant the Turbo XS MBC, not the BOV, and by the way superglue will not hold that, I had to go with JB Weld.
ok i have the turboxs mbc too. since i gave you a hard time i will tell you how to do it. the blue nipple on the mbc goes to the bottom of the waste gate. The copper nipple goes to the turbo nipple. For some reason with the turboxs any other way it wont work. let me know if you have any troubles or any other questions
UM...I'll just pretend I didn't see that post above and answer your question. Find a boost source somewhere between the turbo and your throttle body. Sometimes there is an output nipple on the compressor housing, but if not just tap into your IC line. Connect a hose from this boost source to the input of the boost controller. Connect the output from the boost controller to the wastegate.
Back the knob out all the way and test. The turbo should only boost to the stock wastegate setting (normally 10-15 psi). Then slowly tighten then adjustment knob until higher boosts begin to register (slowly as in 1/8 turns). Hope this helps.
with the turboxs model you have to go to the nipple on the compressor housing. Otherwise you will hit nearly 30 lbs of boost. atleast this is what mine did when i tried to just T in to the bov line.
