1g no turbo into a 2g TURBO
-=TWITCH=-
826
2
Sep 4, 2002
Columbia, Missouri
I’m about to upgrade my turbo and my buddy wants my T-25 I’m going to trade my T-25 for his entire 1991 engine block and head. I was wondering if the block would work in my car even though it is not a Turbo block? I want to send it off and Have it rebuilt and bored. If the block will work, I will just keep it around just in case. Can I have the block milled to accept my 1995 turbo piston in case my block decides to walk? Please let me know what I would need and what I would have to be done to the head and the block to work thanks allot for any help.
Search the archives, this has been discussed before.
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=5986&highlight=nt*+block
The oil squirters are different.
It will start, if that's what matters, but I wouldn't expect it to push major HP without "complaining".
Don't even consider re-using your pistons in his block.... they are only about $40 each from a dealership! NEVER do a "cheepie" engine rebuild, you will not be happy with the results.
If you want an engine you can beat on, or make some good major power on, this will not be a good motor, unless you are ready to invest a lot of money into bringing it up to spec.
