Bigwilly6754
- 129
- 2
- May 28, 2002
I have a 97 GSX i just bought a green and all the other good to go along... Now im wondering how much power can i make with the stock cams????
Originally posted by candela
there is not answer so why dont you be the test dummy? Noone knows how much power can be made... each setup is different bla bla...
There is no set amount of power you can make with them as Ive said numerous times before. Some people have made a lot some do headwork and get cams before they even start to maximize the stock ones. As I said earlier some people have made a little more than 400whp some a lot less. Dont be an asshole cause noone replied "" Yes Mr. Willy
you can make 450whp before you have to upgrade your cams...""
nowhere in your original post did you ask if it was worth it to keep the stock cams. A whole bunch of people said that in previous posts, then you posted again that you wanted to know how much power you could make with stock cams. At which point your question was answered, for the second time. Oh and did you know that you can use periods to string together 3 thoughts into one post? If you need a lesson in grammar and sentence structure I suggest you check www.Imstupid.comOriginally posted by Bigwilly6754
Yea ok!! i think my question is perfectly fine!! I have a big ass turbo on the way all i wanted to know is it worth it to keep the cams or ditch them .....WOW that was hard!!!!!!! ur right its not nuclear physics!!
