2G Fuel pump install?
venom2097
122
May 3, 2002
I finally got my walbro 255. Am planing on installing tomarrow, have checked the VFAQ and found only FWD install, so my Q is...
any tricks, tips or things not to do , any of you have?
Any help would be great, thank!
The vfaq is fine for AWD.
1 Depressurize fuel system
2 remove back seat
3. remove 4 screws on cover
4. unplug power to stck pump
5. remove fuel lines
6. Pull old pump out
6 put new pump in
7.reconnected all hoses and power
8. start car
9. check for leaks
10. out cover back on
11. put seat back in
Your Done
Later,
One thing to keep in mind. You will need to disconnect the fuel feed line under the car.
Watch out for the outter white ring, it can be a PITA.
You might have to modify the rubber bushing on the fuel pump... cut it a little bit because the pump size is slightly different. (not really a big deal).
Take your time and you will do fine. Just be prepared to spill some gas.
When I swap out my ND155L for Supra TT I will make a page on my web site.
Well it was vary simple, except for 2 parts.
1. the damn screw on the "L" thing, I never did get it off.
2. the Fn bottom fuel line would not come off, so I got the top to finally come off then couldn't get back on- without twisting the stupid hose.
so 15min to get them switched, 2hr to get the hose on.
