tsigeoff
- Sep 17, 2002
I figure I'll post this in here....it has stumped me and 6 of my buddies.
I get major league boost creep! I have a homemade dual stage boost controller. I run the stock 10 lbs, then go to 20 when I flick the switch, so I use the stock wastegate and boost solenoid. I have tried three different wastegates, so I'm beginning to think that's not the problem...I have redone all my vacuum hoses, everything. I've even taken off my boost controller and I got to 10 psi, then at about 4500 rpms, it shoots up to 25! The same goes when I have the boost controller in. I have no clue why it is doing this.....I changed my bov a while back and ever since then it did it. Since then I put the stock one back on and sold that one, so I thought it would be ok now. I'm stumped really bad. I used to have perfect boost, now I'm afraid to get on it, cause I hate running 25 psi. Not sure if it could be a cracked manifold or o2 housing. Any suggestions would be appreciated. NEED HELP PLEASE!! thanks
geoff
geoff
Your posts allways give me a nice laugh ripperXX:laugh:
