RipperXX
- 5,788
- 170
- Feb 23, 2003
Royston,
Georgia
Ok which spolls faster? Big 16G or 20G I ask becouse I hear ppl saying how fast a 20G spools up..
Also what is the max boost each can putout without damage?
and what rpm on MOST setups would you expect the turbo to come on at?
and last question at what point (psi) do the two of them start blowing just hot air...
Well I do have one other question.. which FMIC would work better for the big 16G a DSS FMIC $1,100 or the spoolin up FMIC ($800) the spoolin up has a larger area and flows more air or so it says.. but I dont think it's a direct bolt on like the DSS... but keep in mind if the Big 16G isn't enough to get the whp i want i will upgread to a 20G... sooo which of the two could probly handle both easy.. or could either handel a the two turbos easy? becouse the last thing i wana do after cruseing around is to try to race someone (yea illegal) only to have a heat soaked IC..
However, with the 16g I'd guess somewhere around 25 psi it's starting to get really inefficient, and the 20g is probably somewhere higher, around 28. This is all purely speculation though, you'd have to look at the compressor maps to find out.
The 16g will spool faster...why? Because its a smaller turbo! You say you want XXX HP just like everyone else, youll just have to go in stages and see my man. NO need to buy a turbo where yoru at right now anyway.
(i kinda wana make it a mid to low 11 sec car but i guess that would take along the lines of 500+hp sooo since i dont wana put 9+ grand into it to bad for me i guess..
