HELP turbo install
droptopgst
270
Oct 1, 2002
Myrtle Beach, South Carolina
I am in the middle of installing my TDO5 18g on my 98 gst. I have no clue where theses lines go. They sent me a stainless steel line. where does that go. do I ust both of the banjo bolt fittings or not. how about the oil line that runs down to the oil filter area. I was told that with this turbo I would need to run the oil supply line to a diff. location. No clue where though. someone please help i need to finish this before it gets dark. Thanks
The SS line is the oil feed line for the turbo! You might have to use the oil wource from the head? Im not sure about that! do you have any pics of the stuff that you have no clue about?
Chris
I had that same problem, there's like a 19mm bolt on the left side of the head, unscrew it. thats where your new oil feed is goin to be. do not overtighten either, you dont want to damage the threads on the head
