20gst
- 174
- Jan 5, 2003
I got a HRC super 20g and Im going to change the 10cm exhaust housing for an 8cm and go with an external type set up. My turbo has a Compressor Inducer/Major Diameter of 2.075/2.675
Turbine Exducer/Major Diameter of 1.930/2.200
Will my exhaust wheel work with an 8cm ok or what ? This turbo is a Mitsu., and I dont know whare to find any housings for em, do any of you know whare I can find it at or buy one.
The reason Im doing this is because I think my internal flapper is broken and Im loosing boost here. I tested everything else and this is my only answer. I will know for sure this weekend when I pull it off to see. Thanks............
he said he wantsto get an external. Anyhow the HRC turbo's are still mitsu which means its the same as any other 20g except you have that dumb ass 10cm housing. Just about all 20g's have 7cm housing on them anyway, td05h or td06 dont matter. Im sure youll pick up some spool and maybe even a little more midrange. Ive only been in a super16g car not a 20g, but I have been in a regular 20g'ed car... HRC's housings stink
I think getting the 7cm, porting the nuts out of it and putting an external on the manny is a great idea
