DELTA_Rotary
- 147
- Oct 17, 2002
Well my order came in the mail today. AGP L3R I got a good deal on it from Unreal. The only thing I was surprized about was that I assumed that the wastegate hole would have the flapper removed and set up for the wastegate on a 02 housing like the one in the picture. I guess thats what I get for assuming. As you can see the flapper is welded shut. I guess this means I have to (A) tap my current exhaust manifold for the wastegate (B) buy a custom exhaust manifold made for an external (C) Port out that wastegate hole on the turbo myself and remove the welded flapper (D) just use it as a 1300 dollar paper weight.
Does anyone know if option C is even recommended? I would really like to use the 02 housing setup I have with this turbo but I dont want to mess this turbo up and be left with option D no matter what.
Well here are the beauty shots.
Andrew
Andrew
