injector spacers?
You have to get them through satan, part # MD095402 It's called a Fuel Injector Insulator. (Even though it's a Fuel Rail Spacer)
Just a tip: Put some blue RTV on one side of them and put them in the little holes where they go and let them sit for about 15 mins before putting the rail on and they won't fall off next time you pull off the rail.
Not true.
I trashed my o-rings doing an injector swap (remember to lube the damn things) and had no trouble getting a set from a local auto parts wholesaler. I believe that the kits I bought (which contained both the top and bottom seals) were made by Beck-Arnley; they've been on for over a month now without any problems.
They were also pretty cheap.
= Mike
Originally posted by DrZiplok
Not true.
= Mike
I think you're right Mike, Napa tried to sell me injector spacers when all I wanted was O-rings. I believe the set was about $8.
Not true.
= Mike
He's not referring to the O-rings, he's talking about the insulators that sit between the fuel rail and the head....
