FMIC Pipe Size
TurboTerror
189
Nov 3, 2002
I have a big FMIC for my 1G Laser. The pipes on this thing are 3" in and out. The only thing that I am wondeing is would it be benefitial for me to use this size piping or should I step it down to like 2 1/4" piping? What would be the benefit/downfall os using either one of the sizes of piping?
It depends on the amount of air you're going to be moving. With a 20G and below IMO 3" is WAY to big. You'll get pressure drop like a biatch not to mention a ton of lag as your turbo will need to pressurize all that volume inside your piping before it gets to your engine. Try to step it down to 2.5" if you have a medium range turbo (18g/20g/green) or 2.25 if you have a Big16g/16g/14b (You really shouldn't be FMICing your 14b gas unless you're trying to squeeze out 12's). Hope this helps.
Thanks, that was the exact type of answer that I was hoping to get out of my question. My actual setup is:
HRC Ported Super 16G
Evo Exhaust Manifold
HRC Eliminator O2 Housing
Fidanza Flywheel
ACT 2100 w/Six Puck Disk
550cc Injectors
S-AFC
MBC
Full 3" Turbo-Back
Intake
2G TB Elbow
Poly Motor Mounts
Balance Shaft Removed
Pocketlogger
Boost, A/F, EGT Gauges
Stevetek Fuel System
Sumped Tank
Accell High Pressure In-Line Pump
Pressure Regulator
Now do you think that this setup would still be wise to use 2 1/4" pipes. That was what I was going to use to build this up considering the ease to work with this size of pipe vs. 3".
With this setup I am hoping for some 12 sec passes this summer.
  • Wanted 2g Ac tensioner
    Looking for ac tensioner and pulley for 2g
    • Simo_217
    • 92AWDHX40
    • eclipsemf
