Upgrades, Injectors and TB for 2g
tominatortwo
100
5
Jan 5, 2003
Indianapolis, Indiana
I am putting together a 500hp+ motor what size injectors will I need and will a 1g TB be big enough to handle air flow also will the 1g intake manifold e-honed do the job?????????????:confused:
720's and I suggest getting a sheetmetal intake manifold and bigger TB.
Thanks for the information I will get the stuff that I need.
what turbo do you intend on running and how much boost? 500whp or crank hp? what type of tuning setup are you using?
Injector size will change dramatically if you run something like a haltech vs something like an AFC :)
The turbo is a 25g and crank HP is what I want, also want to run 25-28lbs of boost and 850 injectors.Removing AFC, 550's and 16G and installing a AEM and wide band 02 sensor.Switching from MAS to MAP sensor.Raising red line to 8200rpm with stiffer springs and retainers,using 264-272 cam set up on head 3' exhaust no cat removing balance shafts.Want a car to be in the low 11's,
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
