ZDOGG
- 38
- Apr 24, 2002
I just bought an AVC-R and I am currently installing it. The manual says to put the pressure sensor between the fuel pressure regulator and the surgetank(intake manifold?). The problem is that there is a check valve between the surgetank and the FPR. Which side do I tap into, the surge side or the fpr side?
Also, I didn't get the air filter(that goes between the pressure sensor and the vacuum line) with it since I bought it used. Do I really need this? If so, where can I get one?
Thanks,
Zach
Thanks,
Zach
