Razor_DSM
- 97
- Jan 14, 2003
North Adams,
Massachusetts
Basicaly, my engine is blown, timing belt snapped. destroying one of the pistons and a coupple valves...
I intend to have the block reworked. what would be the best bore to go with when i do that, i will be running it with the stock fuel pump and injectors for a while and no turbo upgrade for a while either. I would like 15psi before all the fuel upgrades, and then hope to hit 20 when i get the BIG 16g and all the fuel upgrades, this will be a dialy driver too... so reliable with these specs would be good
RODS - what ones should i get... i know crower is #1 but i dont plan on pushing that much HP, my goal is 350-400, and the price is a little overboard for me.
Turbotrix has Eagle rods at allmost half the cost, but how good are these compared to 90' rods? and is it really worth it?
PISTONS- Again there are alot of choices. Ross street pistons come with the rings at a very good price, are these better than 95 pistons? if i decide to go with stock 90 rods, will they need to be machined, like they would for 95 pistons?
ARP BOLTS- Should i go with just the head bolts, or the main and rod bolts as well?
TIMING COVER WITH OIL PUMP GEARS- Yes or No? a rather high price tag, if it doesnt need to be replaced, id rather put the money eleswhere.
also while im in there, should i do the balance shaft removal, and is there welding involved?
HEAD GASKET- Multi layer steel is the best for the $$ right?
Oh, standard and oversized berrings, what are the differences, and what will i need
rather than take up everyones time furthermore, ill ask about the uper engine later, please help me out, and if you can think of anything elese that im missing on the lower half let me know.
