Steel Hawk
- 50
- Oct 27, 2002
This may be a newbie question...
I've done some research, but still can't find the answer. Assuming the following is correct:
The PCV valve is a one way valve that takes excess blow by from the head and sends the air / oil vapors into the intake -> ic piping -> intercooler. In the intercooler the oil vapors cool down and it results from oily film to small amounts of oil. The oily air reduces the octane rating, thus reducing performance and causing a greater chance for detionation. (Although it's an extremely small reduction).
There's talk of catch cans, leaving it alone, etc.
Now heres my question. Assuming you just left the PCV valve on (by itself it doesn't do anything except let air out) and attached it to a hose running to the ground (and plugged the intake manifold), what would happen? I assume there wouldn't be any performance problems, and a few drops of oil would come out and stain your drive way, but would it be bad?
I mean would oil run out of the car all day and leave huge stains over the road? Just curious.
edit:
also, would I loose performance due to vaccume pressure?
Thanks.
edit:
Thanks.
