Kapok6
- 1,393
- 271
- Aug 10, 2004
Fort Worth,
Texas
I have some questions about modded crank case ventilation systems. On my previous motor I built years ago, I was foolish, and only had your typical two stock sized lines from the valve cover to a cheapo catch can that vented to the atmosphere. Well, I produced oil leaks pretty quick and was blowing the dipstick out any time I got on it.
So I started to research and ended up doing a system nearly identical to Paul Volk's. Two -10AN's from the valve cover to a sealed catch can, (Calan), then from catch can to turbo intake pipe with a -12an. My dipstick stopped blowing out and my oil leaks went away. Yippee.
Fast forward to now, with my new motor. I put the same system back on, with one small mod, I incorporated what Jacks did, (http://www.jackstransmissions.com/pages/jacks-pcv) by adding a line from the stock PCV valve to the intake manifold. From the moment I turned the key for the motors first start up, it idled perfectly, and has ran GREAT for the last 500mi. No oil leaks, dipstick does NOT move, etc. Rings sealed in the first 10mi of beating the piss out of it. No Smoke whatsoever after the first 10mi.
But this got me thinking, how are guys getting away with running just two lines to a vented catch can with no connection to a vacuum source and not having ventilation issues? For instance the guys with forward facing turbos and no intake pipes or filters? Is crank case pressure not an issue if you have good ring seal, and as such, have no need to run a line to a vacuum source?
The reason behind me asking this is that I am wondering if once the rings are sealed, can someone like me just eliminate the turbo intake pipe and the line running to it from the catch can with no ill affects?
