Atari007
- 193
- Apr 18, 2002
Jacksonville,
Florida
I was just kinda thinking about this tonight... I dont have a DSMlink, but if I am correct, you can advance the timing with it according to RPMs... well...if you see that you always get a high knock count at say 4500 RPMs and your ECU retards your timing say... 5 degrees... couldnt you just bump up the timing at 4500 5 degrees? I mean... you really arent getting rid of the knock, but if you are pretty sure that it is phantom knock, would this work? or would your ecu see that and continue to retard the timing beyond what your settings are? Like I said, I dont even have a DSMlink (yet), but this is just something that I have been thinking about..... any ideas? Thanx--
But yeah, I guess suggesting other avenues would be better. I just didn't want some fool to disconnect his knock sensor, cause knock is bad, right?
