1g fuel levels
Supa Dexta
452
Sep 12, 2007
Edm,
Does anyone know if the fuel level float setup is the same between the awd's and fwd's? Mine is trashed, so I have to look around for a replacement, I'm just talking about the float arm and resistance coil that bolts into the entire sending unit. (I don't care so much about the arm length or shape, I just need the resistance and mounting bolt holes to be the same)
According to the FSM, the FWD/AWD senders output the same values:
Full = 3 Ohm
Empty = 110 Ohm
The main difference being the orientation and travel of the float due the the difference in mounting positions.
<FWD>
Point Full 43.1-48.1 mm (1.69-1.89 in)
Point Empty 175.5-179.5 mm (6.9-7.06 in)
<AWD>
Point Full 21.3-24.3 mm (.84-.96 in)
Point Empty 199.2-202.2 mm (7.84-7.96 in)
Measurements are from the fuel sender top on AWD and midpoint of fuel sender on FWD :dsm:
