Bov
domenico_169
428
Sep 17, 2002
Edmonton,
hey boyz i got a quick question about the hks ssqv. i was wondering how hard it is to intall it on a 1g and what i need to do it. thanks:dsm:
2 big washers and 2 small ones. Set the BOV on the flange, put the stock bolts through the washers, and use the washers to secure the base of the valve. That is the cheap way to do it, it is still rock solid, but cheap. The other way to do it is have the proper flange welded to your IC pipe.
The size of the flange depends on what type and size of piping you are using. If you are using aluminum, then there is only one flange. If you are using what I consider standard 2 1/4" Mild steel pipe for you setup, then you would want the 50mm. If you are going will a full race type of setup and using 3" IC pipe, then you want the 65mm.
