SOURCE1064
- 954
- Apr 15, 2002
Paramus,
New Jersey
I consider myself to be quite knowledgeable about cars but I have a question about what I'm doing on mine. I see posts about stroker kits and I wanted to know what changes the car's displacement the .3 liters?
Here is my setup what would my car be considered? 2.? liters.
Stage 3 Racing Short Block Work
8 Hours of Port work
Extrude Honed
Balanced
Blueprinted
HKS Metal Head Gasket
Stage 3 Racing Head Work
Hot Tank
O ringed
Pressure Tested
Resurfaced
New Valve Stem Seals
Bronze Valve guides
J&E Forged Pistons 9.0:1 compression, .020" oversized
Eagle Forged Connecting Rods
Nitrite Coated Stainless Steel Valves 1.0mm oversized
Crower Titanium Valve Springs With Retainers
Clevite 77 rod bearings and main bearings
Buschur Racing Balance Shaft Eliminator Kit
Knife Edge and Balance Crankshaft
HKS Cams 272 degree intake and 272 degree exhaust cam
Extrude Honed
Balanced
Blueprinted
Hot Tank
O ringed
Pressure Tested
Resurfaced
Bronze Valve guides
