TSiAWD91
- 62
- Nov 14, 2002
I noticed that the manifold outlet is HUUUUGE compared to the inlet on my 13b,and i was wondering if this will cause any problems.I know it wont be the best thing for flow,but should I see any negative effects that could cause the car to not run right?Also when I replace the turbo/manifold gasket should I cut the gasket hole to match the manifold,or leave the hole thats in there to match the stock turbo.I havent recieved the gasket yet,so I dont even know if there is a hole or if its different then what Im thinkin it is.I just wanted to post this cause Ill prolly be finishing up the head replacement tonight,so Im hoping for an answer by later on today.Thanks!!
) turbo, you can port the evo manifold and new exhaust housing out.
