fp internalgate green?
WhyteSpyder
60
Jan 7, 2003
I'm thinking of running a fp internalgate green turbo, but just how well will it hold boost? I plan to run from a low of 17psi to a high of 25psi. Will I be fine with the internal model, if not I guest I will settle for the
t-28.
Just make sure you get the larger flapper on the internal gate, minimum 34mm flapper door. Otherwise, if you try to use the stock sized flapper door, you won't be able to hold lower boost levels. With the larger flapper door and the internal, I don't see why yuo shouldn't be able to hold 17psi.
