Problems with s-afc
genxxxracer
123
Dec 22, 2002
I just installed the s-afc and it is not registering any air flow. The car wont idle for crap. I checked the wires that connect to the yellow blue wire and they are well connected. I did the install according to the vfaq diagram. I am lost, what should I check/do next.
Brent
Ok I figured out some of my problems. I hate to admit but I didnt set the thing first when I had it hooked up. After changing it to 4 cylinder with the Karmen it started running normal. I still have no clue what to set the throttle high and low and the other things to. Anyone have any ideas.
I did that...set it to 30low...80high
What I would like to know is how much plus or minus for each rpm setting....right now i have it set at -25 at 1000 rpm's and increasing 5 percent for each 1000 rpm's. I dont have the egt hooked up yet so i cant tell if im running to lean when the rpm's get up there.
Hey genxxxracer, if you want to meet up sometime I will help you tune the car. Just let me know
Austin
    • eclipsemf
