wanna port my 14b
RossY
627
2
Sep 27, 2002
Canton, Ohio
i was reading on the vfaq site about porting the turbo for better spool up and im curious if porting the turbo inlet is all that i should do? Of course i would port the mani to match but other than that is there anything else?
Originally posted by 97gst-eclipse
I would also port the wastegate area while you are at it.
Ok, if i did that what difference would it make and what would it do?
Make less of a chance of having boost creep.
alright then thanks, for that. BTW i already did the inlet and the mani so next up is the wastegate. Anything else while i have the motivation?
Well, you could port the o2 housing also! ;)
ah yes, this brings me to another question. Im going to be getting a 2.5 SS o2 elimator exhaust system. My question: Isn't the o2 eliminator the replacement o2 housing and if it is then what is different about it or what makes it flow better.
You might also want to port out the turbo outlet to match the new O2 housing. Just don't port near the turbine wheel.
