t3 compressor wheel
dsb97gst
Aug 15, 2002
Tucson, Arizona
i was wondering if anybody knew where i could buy a t3 compressor wheel like a 50 trim cause i need it to bolt up to my t3 manifold
First of all, you need a complete turbo. 2nd a 50 trim is not a t3 wheel.
AGP turbo is in Phoenix, and could get you everything you need to do a t3/t4 setup.
If your in tucson, you should hang out with the DSM people here or something. My roommate has a 95 gsx and just got an AEM. He has a t3/t4 on his car, and so do I.
Nick
93 Talon
i have a garrett t04b v1/v2 trim turbo and i have a manifold that bolts up to a t3 so i was wondering what i needed to bolt up to the manifold
Check out www.turbonetics.com They have all kinds of data on the T3 turbos. The T3 50 wheel is like Mitsubishi 14B size. It's not a popular upgrade in DSM land. The T4 50 trim wheel is much bigger and is very popular.
Well...
I hate to be the bearer of bad news but you'd be best off selling that turbo and starting over with a t3/t04E combo. None of the parts on your v1/v2 are very desirable. The compressor is only slightly OK for use on a DSM but not ideal by any stretch of the word. And the entire turbine side is wrong for the manifold you have. T3/T04e's can be found for relatively cheap and are better suited for our applications. If you really really want to save a buck and run that turbo the email me and I'll quote swapping the turbine side out for you.
[email protected]
