ngk 7s or 8s?
Hiitman
482
3
May 12, 2004
Colorado Spring, Colorado
should i be running 7s or 8s with my setup? i keep getting different opinions from different people. im stil checking everything (boost leak, exhaust leaks, knock sensor, ect) but i was wondering if the 8s will help with my knock issues. i attached a log from earlier and heres a list of my setup.
2.4L. wiseco pistons and eagle rods. hks 272s. aem tru time cam gears. arp head studs. fluidyne radiator and 1360 cfms push/pull slimline fans.
3" dejon intake, NGK plugs and wires, greddy turbo timer, 3" Thermal exhaust no cat. AEM wideband UEGO, 255 lph, 850s, aeromotive fpr, dmbc, 1g BOV, sbr exhaust manifold w/ turbosmarts 38mm wastegate, sbr-G50. godspeed fmic.
thanks thats a great thread
Not able to view the log here, what kind of boost are you running? I have been running the 7's for several years now & thought I'd try the 8's as I was going to the track & thought they may help with knock running 22 psi. Installed them the day before & seemed to get more knock then with the 7's. Got to the track did several runs & they all knocked. Switched back to the 7's & knock was basically gone. Don't know why but the 8's didn't seem to work at all for me.
I have some of the BR7ES plugs on order (non projected tip), so was going to give these a try as well, to see how they compare.
why dont you post that up on the dsmlink forums, you will get much more accurate help their. Im assuming from the file name layout, its a DSMLink log.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
