Blown Turbo?
BLITZ SPYDER
ok..it simple...LOTS OF white SMOKE! and it smells like burnt oil, when I run any kind of boost and step off the gas pedal, the car gets covered in white smoke. So what do you think?
Yikes!!
Check your oil and coolant lines going to the turbo.......
Is the car making any strange noises?
Check your oil... Look for any foreign objects... ( Mostly metal shavings)
- If there are metal shavings your basically ####ed.
Is the car leaking any fluid (oil/coolant) ?
Could also possibly be a head gasket...
Is there coolant comming out of the exhaust??
found the problem, believe it or not it was very simple..I had the wrong hose connected to the breather port on the valve cover. Once I removed the hose and replaced it with one of those (APC)...don't laugh! filters the turbo stopped smoking. Anyways, thanks for the help!
    • 92AWDHX40
    • eclipsemf
