20g support eqip.
Dylan
ok i was thinking if i were to uprgrade evertthing first that i would need to be able to use a 20g turbo then i could just wait till i can afforsd it and drop it in with no problems. BUT will this screw things up due to the time it will have the t-too-small (t-25 turbo) still in there?? and also will the 20g (plus instalation kit) still all fit where the t-25 was before even after i upgraded everything else around it?
Get 660's, fuel pump, 3" turboback, FMIC, bov, port your manifold and o2 housing, safc or some type of fuel computer, logger and you should be good to go. You can still have the t-25 on there, but 660's might be a little tough to tune with the t-2small
