Turbo
- 160
- Sep 13, 2002
houston,
Texas
In the time working where I work I have recieved thousands of phone calls. Many of them are from you guys. People with the 2G's
want 16Gs, 19Cs, Big16Gs, 18Gs, 20Gs & Godzilla's (46trim CW). But almost everyone of you hates having to run the J-pipe (in the 2Ginstall kit) to convert from the Garrett to the TDO5H series turbos.
So now everybody is stuck with dilema of a T-28 Garrett series turbos or The TDO5H series turbos.
So what do you think of the idea of a Brand new TDO5H series turbo Ie..16G,Big16G,18G ext.. with a compressor housing on it that will allow you to bolt it up just like a T-28\T-25 & still retain the use of the factory TDO5H series 7cm2 or the 8cm2 turbine housing instead of the much smaller Garrett turbine housing found on the T-25/T-28 series turbos? Of course you would have the option of the larger TDO6 & TDO6H turbine wheels. You will still have to use 1G oil supply & drain lines or ss braided oil lines. BUT you will not have to use that stupid J-pipe !
Enough of me talking ...Lets hear what you guys have to say .
Wade
Wade
If your looking for a test car u know where to find me,
. Wouldn't all it take is to turn the compressor housing 180 degrees, weld on an elbow, and relocate the wastegate w/ a bracket? I've actually thought about this in the past 24 hours. Strange huh? Oh well, cant sleep, 10 page paper to finish, I mean clowns will eat me. Hasta!
. I personally , during the installation of my FMIC had a 14B with of course the J-pipe on it. I thought that it might have made for an easier installation if the compressor housing outlet were facing the right way instead of down . But hey , thats why I ask you guys !
