madcheba
- 66
- Nov 24, 2002
was doin my usual ebay searching and came across this:
Gain up to 20 HORSE POWER!
Oxygen-Fuel ratios in modern automobiles are regulated by an Electronic Control Unit (ECU). Your factory ECU is set to maintain a 14.7:1 Oxygen-Fuel ratio, this is known as a stoichometric fuel mix. This mix is a balance between power and fuel economy. However, richening the mix will generate an increase in power. The fuel/oxygen ratio must remain between 13:1 and 17:1 to remain efficient, this Oxygen Performance Modification will increase your vehicle's performance by adjusting it's Oxygen-Fuel ratio. Your vehicle's performance will increase noticeably, you will have more power without decreasing your fuel economy.
All parts and instructions are included--installation is very basic and will only take about 20-30 minutes.
This is a great modification for any car, and will indeed increase your vehicle's HP without damaging it in any way.
what the hell is this and does it hold truth?
