fallenauthority
- 692
- 11
- Oct 14, 2004
La Plata,
Maryland
My God, I just got my car back from the shop yesterday after it being there getting a 6 bolt swap for 5 months, yes 5 months, the owner kept dicking me around and taking his sweet ass time but he finally got it finished up. So i drove it yesterday and went to a car gathering last night, as im backing out of the spot to leave i see on the ground a decent sized spot of oil, about 4-5 inches wide. I checked under the car this morning and it appears that the oil pressure sending unit is leaking from where the wire plugs into it, is this even possible? the rest of the oil filter housing is bone dry except for that sending unit "bulb". Then i saw some wires on the back of my motor were wet with fresh oil as well as my firewall. Where the hell could an oil leak be on the back of my block? Any helpful responses welcome, thanks.
So im just going to keep an eye on the oil level and keep driving it and get some brake cleaner and clean it up and see if anymore shows up. I checked to see if his story could be legit and i did see a bit of oil by the oil cap on the intake manifold and some going down the back of the timing belt cover. So ill clean her up and check it out each time i drive it.
