brrrnntsshhhh
- 75
- Aug 28, 2004
Tucson,
Arizona
I just did a compression test and cylinder 4 runs 175, the rest of them run 145. My motor has 217k miles so i figure the 145 would be normal wear and tear. Am I wrong? What should I do? It was rebuilt sometime before i bought the car at 180k. but i dont know why one would have really good compresssion and the rest would be low.
I think it is my headgasket because i was blowing smoke, sort of a whitish grey color - but i was running a bit rich also on 880cc injectors with dsm link. I did look in my coolant and dipstick and very hard to tell if there is any oil in the coolant or vice versa, are there easier ways of teling?
Also my valve cover gasket was leaking oil onto cyl 4 which could have caused the smoke. I fixed this problem. IM also doing the rear motor mount and have started doing the timing belt, I was wondering if it was worth putting back together to let it run and see if it still smokes?
plug on cyl1 looks a bit rusted like maybe coolant was in there or something. ideas? confirmations?
thanks for your time,
troy
troy
