Can I turn up my AFPR to check for leaks?
chicagoavenger
981
13
Aug 17, 2004
Rio rancho, New Mexico
I have a feeling that I have a fuel leak somewhere in my system because sometimes I smell fuel under boost. I know by using my logger I can purge the pump but that is what 36psi and I see no leaks. Now I wanna see if under boost I get any leaks. My q is can I turn up my AFPR to 52psi at idle and that would be like running the base 36psi plus 16psi of boost? Sorry if it sounds dumb but I figure I need to ask so I can learn thanks.
When I installed my AFPR the instructions said to turn it up quite a bit past any levels it would ever see, that way you ensure that there are no leaks. I took some normal paper towels and wraped them around every fuel connection under the hood and had it at about 60psi and let it run for maybe a minute and no leaks.
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
    • 19Eclipse90
  • For sale '90 Laser turbo
    • GregPLT
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
