do i have a vacuum leak?
marntson
74
Sep 19, 2002
ok i have looked through alot of boost related posts and have yet to find something like the problem i am experiencing. so i made my own.
first off i am not sure if this is a problem yet or possibly just how my car runs. that in mind here is what is happening.
i have a 92 awd tsi, minor mods thus far. just installed a big 16 a week or so ago. the turbo works fine as far as i can tell, however i set my mbc at 14-15 psi the other day and observed this. the spoolup seems normal until it hits about 10 psi. nice and fast through the lower psi's. then after 10 is very slowly increases to about 12-13 psi and doesnt go any higher if the car is warm (running for longer than 15 minutes). i experience the same boost increase when its "cold" except that the boost climbs all the way to 14.5 psi.
my roommate has his boost set at 18 and it climbs very quickly all the way there. so im wondering if there is something wrong with mine.
i am trying to get ahold of a full 3 inch exhaust ATM, but as of now it is all stock. could this be my problem?
thanks for your opinions.
Did you any maintence work on since you put the turbo on, like change the plugs mainly, because if did and replaced the old ones with platinum plugs, our engines don't like them and tend to do things like what your explaining. But you could very well half a boost leak, check all of your lines especially the ones on your MBC if you have one installed.
yeah i put new plugs in but they arent plats thanks to the suggestions in these boards. and yes i do have a mbc but havent gotten off work when its still benn light out lately so i havent been able to check those lines thoroughly (damn time changes!). thanks for the suggestions i think i will start by changing out the new plugs again, and hope and pray for a day off sometime soon.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
