CL MaNTis GST
- 775
- Jul 16, 2002
Ok, i hope i dont confuse anybody...
First of I just slapped on the new AGP t28. I finished the install last night and started the car for the first time today. I did the whole pre oiling (taking of the spark plug wires and cranking a few times) then started the car. There was some white smoke coming from the exhaust manifold. My dad and I looked at it and figured it was the lubricant I used to pry loose a few bolts that was burning up... so no big worries. I made sure to put in 2 bottles of oil since i know i lost some during the install.. (coolant also). Everything seems to be working fine until i start driving... While in 2nd or 3rd gear it wont boost past like 4 psi. Why is this? I can hear the turbo begin to spool... then around 3 or 4 psi... i cuts off... as much as i press the gas the RPMs wont go any higher and boost totally stops as well.
Now I am using the stock 2g oil feed line because I am waiting on a banjo bolt to use the AGP steel oil feed line. How do I know for sure that my turbo is getting oil. I really worry about this because i dont want to screw it up. There is absolutely no oil leak or coolant leaks anywhere. Although the white smoke is still there after like 10-15 miles of driving and the smell is kinda bad. What would be a symptom of my turbo not getting proper oil... just in case??
Is it my wastegate actuator maybe what isnt allowing me to spool up? When I took it off my stock T25 I broke the little circle clamp that holds the rod onto the turbo flapper. I havent replaced that little clamp... i just put it on the T28 flapper in hope that it wouldnt come off... it hasnt yet, but is this maybe the problem?
Thanks for any help from anyone. I just want to make sure im not going to kill my brand new turbo. I cant wait to spool up that mofo...
please help!!! (...sorry so long)
!! Turbo works like a dream!!!
