PsiRage
- Oct 10, 2002
I heard the eclipse gsx should be able to use ~15psi of boost with everything stock, using 93 octane. Will i be able to get more then 15psi if i lowerd my compression with new pistons from here: http://www.gtpro.com/allproducts.cfm?PID=Engine lets say i lowerd it to about 8.0:1, what kind of boost do you think i should get on 93 octane after the compression is lowered? And does it make sense to lower the compression more and use more boost like this? Thx.. peace
