Gregs99eclipse
- Dec 3, 2002
I currently have the Turbonetics T3/T4. This turbo spools a bit slow for my style. I'm looking for ideas on how to make the turbo spool faster. I have the .63 Standard Turbine Housing. I was thinking about swaping it for the .48 Turbine Housing hoping for faster spool up. Has anyone done this or know of anyone that has and had good results??
. How can I tell what compressor housing and wheel that I have?? (is there any visual difference between the T04E and T04B?) How about my turbine wheel.....The trim is either a Standard, Stage II, Stage III wheel...how do I know which?? I know my Turbine Housing A/R is a .63 but I don't know if the trim is Standard, Stage II, or Stage III. I'm sure I'm gonna need to remove the turbo from the car and bust our the measureing ruler. Help!
Also as farr as my exhaust well I have a 2.5" Mandrel bent down pipe into a 2.5" race pipe (no cat) and a 3" Thermal Mandrel cat back system. I reach 15psi at right around 4,200rpms. Any further questions are welcome
