c0degsx
- 637
- Nov 12, 2002
please dont flame this cuz i dont know #@%#@%#@%#@% about turbos. how much HP would this turbo get me http://www.turbochargers.com/currentspecials/TD05H-16G-7CM2.htm
This factory upgrade for the 89-98 DSM cars increases compressor flow by 25% at 505 CFM at 15 PSI boost """SUPPORTS 340 HP""" .IIt has a larger 7CM2 turbine housings for reduced back pressure at high RPM. It is a direct replacement for the first generation TD04H and TD04H turbos. Second generation cars will require the 2G installation kit
