3.75 GM Mafs?
BudmannG
129
Aug 7, 2004
Waverly, Illinois
Has anyone ran a 3.75 GM Mafs on there DSM? If so how does it perform with it on the car?
The reason I am asking is I have an oppertunity to buy one at a fair price.
It is from a ZO6. It was made as an upgrade for the camaro.
I say it is way overkill. A 3 inch is already bigger than the I/C piping if you doing a blow-thru setup. Even bigger might hurt airflow but making a chamber. This is the same as building a 4 inch exhaust. Not needed but give it a try if you want. Who knows what it can do. Maybe cure cancer?
You can only run it in draw through because it is made mostly in plastic on the one half, also you need a 5 wire to 3 wire pigtail. I bought one that is how I found out.
Check Fullthrottlespeed.com
