wich afpr would be better?
yunior
99
May 13, 2005
jacksonville, Florida
Both of them will work well. Just depends on what hose you want. The push lock hose is abit easier to install but not by much. I personally made my own kit so I could choose the exact fittings/hose I wanted to use. That reg that extreme is selling is abit overkill as its the -10 model, the -6 should be plenty big enough. www.slowboyracing.com also has a nice kit if you want to check them out.
Incase you didn't know - If you get a 190 fuel pump instead of a 255, you don't to get a AFPR.
An adjustable fuel pressure regulator is nice to have though so you know your new regulator can handle the increased volume of fuel, pressure can be set at a constant, and it allows you to increase your fuel pressure to richen things up a bit if needed. Once I get back from Iraq, I'll be adjusting mine up a bit to help out my 550cc injectors handle more boost and the low Cali 91 octane, otherwise bigger injectors may be necessary to handle the 20-21psi I'd like to push dailey :) .
well my 190 has over ran my fuel pressure regulator and I'm now running 50 psi of fuel pressure. i am now desperate for a fuel pressure regulator and have no money to buy one because of x-mas. damn, i hate the holidays!
Is your B&M Fuel pressure regulator turned all the way down? You can only increase pressure above from stock with the B&M, so turn it all the way down. It would be cheaper to just take the B&M out and put a stock FPR back on since 1Gs are supposed to run at 37 base fuel pressure anyways.
I would go with the IE-FPR kit from Import Evolution. Aeromotive AFPR and all the install bits (including a fuel rail adapter that doesn't leak), for about $200. Have one on my car at the moment, and it works perfect.
I have the Full Throttle Speed bolt-on FPR. I liked it because it uses all the stock lines, and bolts directly onto the fuel rail in place of the stocker. This made for a very simple install. and it is already tapped for a gauge. So I just bought a gauge at a local performance shop and threaded it into the FTS FPR. Very simple install, and no AN lines/fittings and custom mounting on the firewall. The AN seems to be overkill to me, because I haven't replaced the stock feed and return lines between the tank and fuel rail, so I didn't see how 2 feet of larger SS line under the hood would have any performance gain at least for my situation.
I have read of a few complaints on here regarding this FPR, but it has been working great for me.
    • eclipsemf
