Tom Sawyer
- 596
- Apr 26, 2002
Portland,
Oregon
Ok, so I finally got the oil feed line tightened properly at the turbo and I go to tighten the fitting at the head. It feels like it's stripping out and then the bolt breaks. I know this bolt and fitting have a special name (dont' know it, I'm retarded) but it's the bolt with a hole in it and a fitting with a tunnel in the middle of the inside for oil to drain down into the turbo. I've called AGP 4 times and no call back. I can't get home for Thanksgiving break if I don't get this bolt. Is this a piece I could find anywhere local or will I have to order it? Your help is appreciated!
Tom
Tom
