Matts95TSiAWD
- 147
- Nov 13, 2004
Louisville,
Kentucky
so.... i just pick my car up from my mechanic who works on DSMs all the time and driving down the road (about 11 miles) at a sotp light my car starts idling like i have a set of mean cams or something, so im like WTF... i start to take off and my all the power is gone (like i blew my intercooler piping off) i turn around and go back to my mechanic and he pulls off my plug wires and (you was power surging from every plug wire when he pulled them when it was running and then he shut the car off and turned it back on and it quit doing it....
so im like ok problem fixed... NOTTT
driving home again it starts doing it again, i kill my motor and then start it back up with the clutch while driving....[<< i dunnno if that is bad hehe]
but ne wayz what would be causing this?!! PLEASE HELP ME!! my mechanic says my coil is going bad and #1 cylinder keeps shutting down
what a new coil definatly fix this or could this be a problem from the ECU since i have to restart my car when it happens and then it stops for a short while?? does a 6bolt swap require an earlier model ECU as well? THANKS FOR YOUR HELP!!!
ALSO
when i start pulling a couple pounds of boost it falls on its face, the nipple on my head cover that people usually put a catch can on... has nothing on it at all is this a leak?
ALSO
