my 60-1 barely clears will bigger turbos fit?
highintenzity4
221
Apr 30, 2004
Mission, Texas
Looks like my 60-1 barely clears, will the fp3575 and fp red fit with the 2g manifold? I have the sbr ported 2g manifold. Thanks.
You 60-1 cleared the water pipe? I had to beat the hell out of it to fit my 50 trim...
what about the fp3575? does it clear with the stock 2g manifold? I didnt know that about the fp red...wow.
This question really depends on WHO you buy the turbo from due to different manufacturers using differently spaced and made turbine housings. I myself only have a 50 trim, but still had to dent my water pipe a bit when it had a true turbonetics turbine housing. Since then I have put on a Bullseye Power turbine housing and now my turbo easily clears by over and inch. As someone said earlier, the AGP turbo hit no problem, this is because AGP actually used Bullseyes turbing housing. Truth of the matter is, Ive checked out a few manufact's turbine housings, and by far the Bullseye is the best for spacing out a turbo. Ill bet you could but the GT30R from Bullseye w/ their housing and it wouldn't hit.
