valve cover removal???
Double check you got them all then go ahead and pry it off. You can also take the oil cap off and get your finger under the cover.
Use a flat head around the seal and it should pop right off.
Even when all the bolts are all off, it can sometimes be a chore, or atleast mine was. I would try to get something underneath the crease and wedge it out. Personally, I dunno how you could miss any bolts? Like the others said, when you go to put it back on, make sure you don't torque down on those bolts very hard, as you will crack the cover.
be very careful when prying it off. Not only can you break it, you can put a gouge in the head, and if you do that, it will always leak oil there.
yeah prying sucks, Mine came off after a few whacks with a rubber mallet
careful with whacking as well, it leads to blindness and hairy palms :D
j/k, but if you hit that aluminum facsimile with a hammer hard enough it will crack
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
