ECU wiring questions...
ge-du-racer
Mar 28, 2004
hell, Michigan
Im considering if I want to fix my 92 FWD Auto, or part it out. I got it with a burnt out ECU. I was going to replace it but if ther is a short I dont want to destroy a $300 ECU. I check the ohms on all the wires. I was told that anything with 0 or real low was ground or shorted, however pin 24 is sensors ground and i got 540. I got 0's on pins 1 2 3 9 11 12 16 22 57 60 62 65 and 107.
Sounds to me like way too much wrong with it. Im I correct in thinking that all thoes pins are shorted or the sensors are bad?
Dos it make a difference if the battery is in it or not?
Is the ignition system magneto? I was told that it is and is not worth trying to fix.
The car has a great body, but is an automatic and it has 200,000 miles on it.
What do you guys think, fix it or part it out??
-Jeff
:dsm:
Hmmm, 92 FWD Auto with 200,000 miles OMG What engine does it have in it the 1.8, 2.0 or the 2.0 T? A wiring harness and ECU can be had for under $400 but changing out the harness is labor intensive and requires you to remove the dash. (Been There) If it were up to me depending on if you already have a DD or not I personally would part it out just because of the milage.
Oh yeah its a 2.0 turbo.
You either have major problems with your harness or your off on the pin numbering and method of testing. The pinout is on the VFAQ site and it's looking at the ECU connector, you have to mentally convert the pins when looking at the harness connector.
Steve
I've got a wiring harness for sale if your looking for one. It's in the classifieds with plenty of pictures.
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
