Which gaskets to use for Ported Componets?
irn__man
256
Oct 8, 2002
New Orleans, Louisiana
Which gaskets do I need to use for the following:
-Ported FP Big28 Turbo
-Ported 2g Exhaust Manifold (The runners are ported also)
Do I use the standard gaskets, or should I go with something different?
thanks
iron
Originally posted by BoostinAWD
metal ones, and port them to match the inlets and outlets
What is the best method to port the gaskets? Dremel? Die Grinder?
thanks
iron
actually when FP ports the turbo they port it to 7cm, you can get a 7cm gasket from a couple different places. I got mine from turbotrix but I know you can get em cheaper from FP and from Conicelli.
yeah.. what larryd said... & the stock mitsu exhaust manifold gasket ports are larger than your head or manifold will every be ported to.. so just use the stocker there.
