4 MSD coils?
jazzyjay
216
Mar 27, 2003
I have seen the 4 MSD coil set up on a lot of car and wanted to know where I could find the write up/directions to do this install. Thanks for your help in advance!
are you thinking of the "coil on plug" setup?
one of the vendors i believe sells the coil-on-plug setup.
No! But if you have the wiring diagram for that I could use that also.They will wire up the same way.
Buschur has the same set-up for 275, they don't say to much about it though, except that it is "PROMISED" to be in stock and ready to ship.
David
