NX2000Guy
- Nov 2, 2002
Does anyone know what needs to be done to make this work? My friend got one with a short block that he bought, and it looks like the vacume lines are diffrent. Any ideas?
~Ryan
~Ryan
Originally posted by GRNDSM
LaserRST, this is a valid concept, which can give you less lag and more bottom end torque WHEN it is properly controlled by a JDM ECU. With out it, it is worthless...
Leon
RR
Originally posted by LaserRST
(Quote)I am sorry, but I do not listen to what people "feel".
I understand that... look into Toyotas TVIS system and Ford Cobras intake analysis, VGI vs FGI. They could probably produce some numbers that may reveal the benefit of a VGI. As far as the Mitsu Cyclone, I didnt dyno my engine with out it but plan on doing some dyno testing to adjust my cams soon, maybe if I find a cheap used USspec manifolds Ill do the work and dispell the myth. Though to further my experience with this new manifold, I can peel out all the way through first, second, and halfway through third from a dead stop without spooling the turbo first, with my US spec I can do this with revving the engine up to 2.5k-3k if I had a cool clutch but wouldnt even chirp in third. I was amazed and impressed with the differences, for what its worth....
Cant wait to see how it feels with a Quaife diff![]()
Originally posted by jdmawd
if i dump the clutch at 5k i can smoke all 4 threw first gear.... what does that prove you ask? exactly nothing. i hope you understand the point.
just so you page flippers know. 90% of those who have forced induction on there 32v cobras dont run the butterfly valve. FMS makes a delete that everyone uses that is going fast with forced induction.
