Race94
- 1,151
- Jan 6, 2003
Puerto Rico
Well i just did my swap(6-bolt) and i just noticed i don't have a knock sensor installed, is there any danger?
What should i do?
avoid?
Thanks
What should i do?
avoid?
Thanks
BrokenTsi said:2g's dont require a knock sensor. Datalogger will help you out with that. Just watch your timing and make sure its where it needs to be.
Syndicate13 said:Jesus, could there be a more incorrect answer?
Anyway you will throw a CEL for not having a signal from the knock sensor. The car will go to limp mode and not run well at all. I would suggest that you take the sensor out of your old 7 bolt as long as it's not leaking and install it into your new motor. Good luck.
Race94 said:the car does not have a cel on
my question is could i break something?
I can't find my old sensor and i have a race in a few days
