Whats everyone using for a fuel filter
gsx rated98
536
Mar 16, 2004
LaPlata, Maryland
Im going to be redoing my fuel system here soon, and i was going to get a K&N fuel filter, but they dont seam to be making a 6an filter anymore. What is everyone using for a filter. It will be hooking up to my stock hard line, and going to a 6an braided SS line. I have looked all over for a fliter that will work, but both K&N and Aeromotive have both gone bitter then what i want.
Thanks Jerry
On my 1G, I ended up going with one of Earl's AN-06 in/out fuel filters...
http://members.ozemail.com.au/~earls/il_filt.htm
IMO, a good filter... filtering down to 35 microns with a replaceable/cleanable sintered bronze eliment. -Just be sure that the AN-06 ends on it are TIGHT!!
You can also get the flared female metric 14mm to male AN-06 adapter from them if you are planning to use the OE line... You will still need this eventually, even if you are planning to replace the OE hard line from the tank to the engine bay. -You will still need this adapter to go from the OE fuel tank's pigtail to your new AN-06 line. For use in the OE fuel filter location, you will also need an AN-06 female to AN-06 female coupler.
i have the earls 6an filter also
it is still sitting nice and pretty in the package along with my russells 6an hardline
flare adapters and various other pieces waiting for install
Thaqt K&N filter you are looking for K&N never made it. Its Made by GOLAN INDUSTRIES, The Edelbrock filter is also a Golan filter as is the MR gasket one.
900 GPH flow baby :thumb:
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
